I bought LED strips on ebay that have 3m tape. Super bright and don't use much juice. They work great.
I bought LED strips on ebay that have 3m tape. Super bright and don't use much juice. They work great.Hey all,
I am looking to get some rock lights for my 08 JK. I do not do much off-roading at night, but I want the option to do so, safely.
I am a little confused as to what exactly I should get.
Most of the kits I have looked at look awesome. But I am confused as to how I would wire them up.
I would probably want to use the remote control that comes with 99% of the kits out there.
Any recommendations?
Yes. I just used a basic rocker switch. No hassle at allSo you can wire them to your battery and a switch in the dash?
I saw those, or something similar. My main concern/question in the thread was the wiring to battery. I must have read it wrong because I thought they where made for home use, and you needed some sort of converter.5050SMD Super Bright White Flexible LED Light Strip 16 Ft Reel Only
here is a link for some LED strips
Use an inline fuse on the wire from the battery to the switch. 5 or ten amps should be plenty. It's not so much for the lights, more just to protect your jeep from fire should that hot wire ever ground.I saw those, or something similar. My main concern/question in the thread was the wiring to battery. I must have read it wrong because I thought they where made for home use, and you needed some sort of converter.
Sorry. I am a newb to jeeps, and wiring.
They are for home use - with a converter plug. However, the reason you need the converter plug for home use is because they are made as a 12 volt system, the same as autos, which means you can wire it directly when using it for vehicles that are 12 volt.I saw those, or something similar. My main concern/question in the thread was the wiring to battery. I must have read it wrong because I thought they where made for home use, and you needed some sort of converter.
