Any guys with rock lights out there? Post up the pictures, brand name and maybe mounting locations. Trying to get some ideas! Thanks!!!
Picture is not my jeep but thought it was really cool!
Where did you wire them into? Did it come with a switch?
Nice Tj BTW!!
Came like this... Cut them apart, soldered in the pigtails cuz the 22g wire was so small then installed 19 LED's total 2-in each wheel well 2 in front 2-on each side 2-over rear axle 1-on each rear frame rail just behind spring mount. 1- over and to left of front DS. Here's a video in true darkness... http://www.youtube.com/watch?v=EK-YLhl18ek
See if this cut and paste works...
Came like this... Cut them apart, soldered in the pigtails cuz the 22g wire was so small then installed 19 LED's total 2-in each wheel well 2 in front 2-on each side 2-over rear axle 1-on each rear frame rail just behind spring mount. 1- over and to left of front DS. Here's a video in true darkness... Rock lights - YouTube
Where did you buy these?
I used these, honestly if I had to do over I would not use them. The only reason they were a lot of work! It's a 22 gauge wire coming off of them so you really need to solder pigtail to them. 20 LED Rock Lights - 4x4 Interior Lights - Truck Bed Lights by HORSEPOWER JUICE http://www.amazon.com/dp/B00H7FYTRQ/ref=cm_sw_r_udp_awd_fC5Gtb09ZA7BF
