Can anyone checkout rockauto.com I have a standard 99 wrangler 4.0 and there are two types of tie rod ends on there can't figure out what is the difference between them.
Knows a couple things...
You mean between their Service and Professional grades? No idea other than the obvious the Pro grade must somehow be better or stronger. I'd give 'em a call to get their likely not too well educated opinion on what the difference is. If you offroad on tough trails, I'd lean torward the Pro grade since the tie rod is under a lot of stress at times.
Retired Admin/Mod
They are one of our vendors and due have a discount code with us as well. Just check the vendor section.
