have a 2014 unlimited and installing exterior lights. purchased a multi rocker switch assembly that goes above gear shift, looking for recommendations for a clean run from the battery to the interior center column. any advise?
go to youtube....search "How to install sPOD"
If you have an automatic, there is an un-used hole in the fire wall up under the dash above the left of the brake pedal.
I just finished install of my sPOD, and used this hole to pull the sPOD harness and 3 other hots with grounds.
The hole is about the size of the old Silver Dollars....need to pierce with a flat blade screwdriver.
You can go in through the fire wall ether side , behind battery or driver side by master cylinder
You can take off end caps of dash to see the holes. I have the daystar panel above shifter ( auto )
Work great
