hey guys, just wonderin how to wire a rocker switch, i want the switch to light up when i turn on the head lights, so it will blend in with the dash (does that make sense:hide:?) it has two seperate lights in the switch.. one when you turn the off road lights on and one when you turn your head lights on. can anybody help me?
so basicaly i want to know that the switch is live...
If im wrong someone will chime in ...the switch must be grounded to metal on the jeep. You need 12volts to the switch and then your load wires to your lights .
