Last year I had to take out the roll bar padding and hard foam underneath because the padding was damaged and so was that hard foam that is connected to the roll bar. Does anyone know where to find those hard foam inserts that go underneath the roll bar padding??
I have an '07 JK
Thanks!
Not sure where you are, and what pieces can be reused etc, but you can have mine from a JKU. Stripping it down this summer.
Hey I wonder if the pipe insulation you can buy at big box home stores would work. Like Home Depot or Lowe’s? That would be cheap and easy. Just have to cut and trim to fit.
Try Pegasus Auto Racing, Jegs or Summit. All of them should have proper roll bar padding. You will certainly have to cut it to fit, but it will be rated for use on a roll bar.
I’ve found the inserts by googling the part number on them. Looks like dealer only. The front pieces above the front doors run about $38 ea. Not such on the rest.
