Looking to patch up my damaged corner panels and then instead of painting, laying on duplicolors roll on bedliner. Anyone had experience with this product? Does it hold up/ clean well being used as an exterior body cover? Any info is appreciated! Thanks
I just got through using it on a pick up bed. It covers really well. I wish I had used it on my jeep tub. I used the plasticote with the chunks in it. Makes hard to clean the inside. The duplicolor has no chunks in it. If you want more texture, use the loop roller in the kit. Roll it on fairly thick let it sit for a minute then roll over it with the loop roller and as it flashes over, the roller will pick it up causing texture. The pick up bed looks like it was sprayed on. Great product. I can't say how it holds up as I just used it but it seems to cure quickly. I wouldn't be afraid to put it anywhere on my jeep.
