1 - 10 of 10 Posts
I wasn't really sure where to post this but I guess this is the best fit.
I have a very hefty double braided rope and want to make loops on the ends without weakening the rope. I was wondering what the best and strongest way to do this was. I didn't know if I could whip the rope together or if there were other options.
I will be using this to pull logs and other semi heavy objects
Administrator
Back in the day, WWII Jeeps had a 1" tow rope wrapped around their front bumpers. Here is a pic of how they made the loops in the ends. Hope this helps.
In the mean time, I just like to say . . .
Welcome to the forum! :wavey:
_______
/l ,[____],
l---L -OlllllllO-
()_) ()_)--o-)_)
Click here for helpful tips for newcomers
If your rope is double braid (one braid inside of another braided casing) the previous post in not how to splice it. It can be spilced, you will need a fiduciary for the size rope you have and a good tutorial. There are plenty of good video tutorials on the web, or if you can get your hands on a copy of "The Marlinespike Sailor" it has a good tutorial in it.
Whipping is done to lock (keep from pulling out), finish and protect a braid like the one pictured above. Without a braid/splice, you are relying on the whipping line to hold the eye. Might be OK for light loads, but I would not trust it to hold for pulling heavy logs. You can certainly try stitch-whipping an eye without splicing the eye in the rope itself, but I wouldn't expect too much from it.
I think this double braid eye splice might do the trick. I haven't tried it myself, but it looks pretty straighforward to do, and has pics with the instructions.
There's also this PDF that addresses different splices: New England Ropes splicing guide
look at a climbing knot called a double figure 8.... it's easy to tie and works well for most applications needing a solid loop....
ranger
I actually found some 3/4 regular twist rope and did the eye splice. How strong could this be?, could it be used for more than logs
A proper splice in twist rope is as strong as the rope itself.
1 - 10 of 10 Posts
