Jeeper
How do the round tails seal against the diamond plate corners? I can see them sealing flush using the smooth corners but with the d/p I dont see how.When I do mine should I use some sealer?
I'd think black silicone would work pretty well, just be sure to not get any on your hands :thumb:
If you use caulk or silicone make sure it is clear. This way if you get it on anything you don't want it to be on it will not be noticable.
I like the silicone idea for the ease. You could also trim a piece of rubber or black foam and sandwhich it between the lights and the d/p.
