Hello, I need to route a small wire from the RV Breakaway Box on the left front bumper thru the firewall into the left floorboard area, is there a plug in that area I can remove that one of you may know of or will I need to drill a hole. I am setting up my JK for flat towing behind my RV. Thanks in Advance.
Commercial Member
If you pull the side dash cover off that is located right next to the speaker you will find a hole though the firewall that is filled with expandable foam. That is where I routed the wiring from my apillar switches to my Bussman auxiliary power panel mounting location.
