OK. I'm slowly replacing the lubricants in my Jeep with Royal Purple Synthetic. Think I'll do the transfer case next. Chrysler recommends MOPAR ATF+4. I found a Royal Purple ATF fluid Amazon.com: Royal Purple 01320 Max ATF High Performance Multi-Spec Synthetic Automatic Transmission Fluid - 1 qt.: Automotive but it doesn't specifically say anything about "+4".
The Royal Purple Transmission Lubricant Cross Reference says, "Chyrsler/Jeep Viper Trans 2008 and up (ATF+4) = Synchromax". By this I assume they mean their Royal Purple 01512 Synchromax High Performance Synthetic Manual Transmission Fluid Amazon.com: Royal Purple 01512 Synchromax High Performance Synthetic Manual Transmission Fluid - 1 qt.: Automotive, which I what I use in my 6-speed manual. Does that mean I can use this in place of ATF+4?
So, is it to be the Royal Purple ATF or the Royal Purple Synchromax Manual Transmission Fluid? Or some other RP product I am missing? CG
ATF for the transfer case. It's synthetic ATF which is what you want. Use the Synchromax for your manual trans. Royal Purple is a good brand to use. I use Amsoil but that's just my preference.
I looked it up since I am doing the same thing. According to Morris 4X4 Center, Auto Trans 4 Qts and NV-231 Transfer case 2.2 pints or NV-241 4.2 pints
