Im getting ready to have the gearing in my jk changed from 3.21s to 4.56s, and wondered if anybody has 4.56 gears with 35 inch tires. I would like to know about what rpm your vehicle runs at around 45 mph. I know thats slow but thats as fast as I go to work because I'm only 5 miles away and in no hurry. The jk with 285-70-17 tires now runs at 1350 rpms at 45 mph and it chugs along. Thanks
To compare ratio you can DIVIDE your old rpms by the old ratio and MULTIPLY by the new ratio.
If you were at 1350rpm for a given situation using a 3.21 rear-end, you'd be at around 1920rpm with a 4.56 rear-end.
To then estimate the change in tire size you DIVIDE by the new size (35") and MULTIPLY by the old size (approx 32.7" for a 285/70-17). So your new setup would be around 1790 rpm.
Current RPM * (New Rear-End / Old Rear-End) * (Old Tire Size / New Tire Size) = New RPM
To "sanity" check it higher numerical rear-ends should raise RPM, and larger tires should reduce RPM.
315/70R17s 4.56 gears. 2010 6spd manual 45 mph approximately 1700 rpm
You'll be happy
