You can cut alot more off. I cut basically all the flat pinch seam to where the sheet metal is bent outwards. Then I packed the opening with some jb weld.
Sent from my Nexus 5X using Tapatalk
I didn't even cut mine, I took a 2lb hammer and hammered it flat. I figure that way I'm not removing steel, which makes it stronger in the long run.
Just make sure whatever you do, that you coat it in rust preventative paint afterwards!
