Wrangler Forum banner
Hello all, Swapping some low milage Rubi axles into my sport. I have the harness and already use my trail dash for tune and gears. My question is...The traildash has a locker and swaybar disconnect dashboard to overide factory locker and swaybar controls.....Is it as simple as plugging in the harness with the new axles and using my trail dash to activate and deactivate the lockers?Thanks for any help and encouragement.
Thanks, I know I can do that. I just want to do it with my trail dash.
Ill give it a shot by hooking it up and reporting back. I figure the Trail Dash talking directly to the ECU would hopefully turn it on. Can only try it and report the results. Would be sweet to be able to do so. if not ill just hook it up to switches.
What was the result of your visit to the dealer?
Was the dealer able to turn on the feature in the canbus?
If not, I am interested in how you connected the control to the trail dash.
TIA
Discussion Starter #7
I gave up, you can connect it to the trail dash via their proprietary cable. Or just throw it on some rocker switches. That was the cheapest option and I was able to use my lockers that day in the mud. So I ended up going that route. And I'm glad I did. It's simple and I have no issues.
