1 - 12 of 12 Posts
OK, so I think I am going to buy stiffer springs and a leveling kit. Now, if I get the stiffer springs, is it still going to have the rake like the stock springs do? I am assuming it will that is why I plan on the leveling kit. How much lift can I expect from a set up like this? Also, will I need to modify anything else, or will this lift be small enough that everything will still work?
What springs do you have?
Gluestick my battle buddy and I installed a leveling kit on his JKU. He still has a bit of a rake.
He's looking for 19 HD springs to bring the front up a little more. Hopefully to even the jeep out. Looking at the jeep- I believe it will.
It all depends on what spring rate your jeep has to start. 18-19's with a leveling kit you should be fine.
Thanks. I am going to check them out. I am on crutches now, so I cant crawl under the Jeep. No towing package, so they are probably pretty low.
First Jeep: M38A1
We have a JK (NOT the one in my signature) with some mods that is currently sitting about 1/2" lower in the front, measured tire to fender lip, and still has the stock 14/57 setup. We are having 19/60 put in tomorrow, and will report back. We're hoping to level, and lift a bit.
Part of the fun is re-aiming the headlights with each change in attitude. That's for another thread though, and there are plenty of them. Springs and lights are very popular subjects.
I can see 3 of the springs rating. I can only see the passenger side front - it is 16. I can see both rears and they are 58. I am not able to see the drivers side front, I do not think there is a tag on there. Can I assume that it is 16 since both rears match? Also, wehre can I buy springs for it?
No. The fronts are usually different. 16/17 front and 58 rear seems a popular set up with the 4 doors.
Having done the swap from 16/17/58 myself on my 4 door, I would recommend you NOT do this. The 19/60 swap is better served on a lighter weight 2 door that has spring numbers down in the 13 or 14 range for the front and 55 or 56 in the rear.
I would expect 19/60s would lift you about half an inch. Not really worth the effort.
Cool - thanks for the help.
Not trying to steal this thread everybody, but MTH I have 12/13/52 springs on my wrangler unlimited X (2007) and I have a friend that will sell me his rubicon shocks and springs (not sure of the numbers but im pretty sure its 18/19/59 or 18/19/60) will this give me a little bit of lift?
Heres my .02... I have an 08 JKU that has 50,000 miles on 15/16 and 58's. Just swapped out for a low mile 18/59 set and gained an inch all around! Not sure if it was the rate or the fact that the new springs had less miles... but I'm happy either way!
just keep your springs and install the RC budget boost. series 2 gives you the links and track bar brackets too. 180 bucks hour to install.
1 - 12 of 12 Posts
