So I have an opportunity to pick up a TJ Rubie T Case. I have been told it is the same as theft Case in the JK. What will I need to change to install into a JKU sport?
I also have a TJ Sport that I have loosely considered swapping it into and going to tons and a stretch......
they also use a different speed sensor system. the jk's use the abs so not sure how that would work.
Ah yes I forgot about that...
I guess I should look at putting it in the TJ, but I need to see about the difference in the speed sensors between my 97 and the Rubie.
The TJ, except for the Rubicon, has a mechanical speed sensor at the end of the 231 t-case. No JK's t-cases have a mechanical speed sensor so installing one in a TJ would require something to run the speedometer and the odometer. Sounds complicated and expensive.
