Hi All
I have a 2008 Sahara Wrangler all stock. Currently with tires that are 255/70 R18. I am looking at Rugged Ridge XHD Wheel & Tire Package.
I am looking at either 305/60 R18 or 315/70 R17. Any thoughts between the 2? Eventually I would like to put a 2.5" lift on the jeep.
Thanks,
Baze
You won’t be able to put either one on a stock Jeep. You got to do the lift before they will fit.
I personally would go with a 17” wheel. Just the difference in tire cost between 17 and 18 is enough to make that decision for me, but the larger sidewall is beneficial off-road as well.
Correction, you may be able to fit the 305/60 18’s on your stock setup, but the 315/70 17’s will not.
Just get some cheap flat fenders and order your wheels with 4.5" backspacing and you should be able to fit although will probably rub a little.
2011 JKU. NBTX
