Hey guys I'm going to use rust bullet on my frame and was just wondering how much should I order don't want to spend $165 on a gallon if I dont have to. I want enough for 2 coats 3 if possible ill be spraying it on. Thanks in advance. :thumb:
I used rust bullet on my oil pan. I removed it scraped all the scale,wire brushed,used Engine Brit then dried it. I put 3 coats on it any finished it with black Rustolum. That stuff is like bubble gum. I don't think it would spray very well,unless they have a different formula. Most of the guys use Por 15 which may spray better. If you jut thin the rust bullet you may alter the formula and that may defeat the properties. It has held up after 2 winters.
