1 - 17 of 17 Posts
So I have a nice size surface rust in my passenger floor board and i want to know what the best way is to remove it and prevent it! I appreciate any reply!
sand it all down, re paint.
Get all of the rust gone.
Prevention:
keep your air conditioner drain unclogged. its on the passenger side on the firewall. its a little tube pointing down. it allows the condensation made by the ac to drip down, and if it is clogged, it goes into your passenger floor board.
Had same problem. Sanded. Primed with rustoleum. Painted with multiple coats of spray rubber undercoating. Worked really well and has held up.
I would clean and sand it then use a rust treatment to stop the rust, then prime and paint. There are several products available I usually use Permatex rust treatment as it is available at the local auto parts stores. If you do not get rid of all the rust or neutralize it, it will come back. Like they say, rust never sleeps.
what brand name is this spray rubber? I literally have a crack in my floorboards that I can see light through....someone is going to put a foot through my floor soon. haha bedliner didnt cover it and I dont want to go through the trouble of welding and sanding...
Hey another guy in a jeep, you can put masking tape over the cracks then put the bed liner on over the tape and when it hardens you won't be able to tell where the crack is. You can also tape over holes too. I use herculiner from autozone and it works great.
I had a hole, I ground down the hole, and wielded in a metal disc.. After bed liner it looks factory... It's worth the 10 min to grind and wield it shut again
for one the carpet is really what holds that moisture that caused the rust. get rid of that and things will progress extremely slowly if not stop.....
Especially the metal heat shield.
Im in that club too except my 99 sport isn't that bad. I want to sand and neutralize the rust then either rubber coat or paint the same color that the jeep is
will the rubber coat seal the floor after the treatment to prevent new rust or should i clear or enamel it?
What about the other side? If you remove the plug you will notice there's probably rust on the underside of that pan. This is why I haven't treated my rusty floor pan yet because I feel the underside rust will still eat through it regardless of what I do to the top side.
I vote to cut out and replace the pan with one of the many available floor replacement pans out there and then rust-proof it with bedliner or whatever you prefer.
1 - 17 of 17 Posts
