I have rustys upper and lower adjustable arms that came with my axles. One of the flex joints has play in it so I want to rebuild/replace. Ive noticed not too many people have had good experiences with them. Should I get the flex joint parts from them or is there another brand that will fit?
Personally. I would just cut my losses now. I don't know if, your heep had them on it when you bought it or you went with Rusty's products but, that is what I would do. I know that it's not what you wanted to hear but, that is just my 2 cents.
They came with the d44 I bought and I needed them due to installing an sye at the same time. Will the currie jj's thread into the rustys arms? Or are you suggesting replacing all the arms with currie?
Does Rustys still use 1.25-12 threads? If so, order up 2.5" Currie JJ's with a 1.25-12 shank. Unfortunately, you won't have much better luck with the junky bushings Rustys uses at the other end.
