so this weekend replacing front ca bushings and putting on new metacloak track bar. planning on floor jack on 44 and jack stands on outside of axel tube. new to this jeep. wheel choak back tires. inside garage. concrete slab. is this correct? safety first..edit front is dana 30 rear is 44
I would replace the control arms bushings by taking one control arm off at a time. (Use a ratchet strap to help realign bolt holes)
When you replace your trackbar, you want the whole weight of the jeep on the ground.
