1 - 13 of 13 Posts
How much space should you have between your bump-stops and your front axel. I only have approx 1 5/8". I think my springs are shot...What is the fix. Will a BB lift help the problem or do I need to replace the springs. Thanks.
97 TJ 2.5l w/ 28000 miles.
Can you run a 2" BB on the rear and new 2" coils on the front untill you can change out the rears as well? Or will it make a bad ride?
it should be fine, just the back might bounce a little bit and be a little lower than the front b/c of the sag
but for a few months it will be fine, however i would just buy a package deal and save some$$
1 - 13 of 13 Posts
