On my 92 yj with full doors and a hard top, the drivers door does not close properly. Here is the issue, it looks like the metal part of the door is lined up correctly as it is in line with the body lines and the gaps are all even. Around the window frame, it looks like it is leaning slightly rearward, and it is also a bit off in the front of the frame and contacts the hard top a bit. Can this be adjusted? Or would I need new doors to really fix it?
from what I have read on line, loosen hinge bolts on door, close door to latch, tighten bolts and check operation. good luck
Ill try that. Of course now I am dealing with the issues from this, while the foorboard under the pedals was just replaced, i discovered a hole in the floor right behind the seatbelt mount.
