1 - 20 of 32 Posts
Krew Member
So, not sure how they happened, but I washed the jeep from my last wheeling excursion and found a bunch of little scratches all on one section of the hood, the picture below you can see the worst of them (the one bigger one). Anyone know a good way to rid myself of these scratches?
the guy at the body shop that i use says if you can pull your fingernail across the scratch and feel it, it will need to be sanded out and repainted. other wise most scratches will buff out with rubbing compound and polish after.
Krew Member
It's not that deep it's just a little surface scratch forgot to add the picture!!
Try turtle wax rubbing compound, their are two diff types hard and soft its has a sort of small grit in it and it buffs the scratch out use the soft one first you really need to use some elbow grease if it fails then go to the second type with a lot less elbow grease slowly, then wipe and wax hopefully this helps
Krew Member
Appreciate it, I will try the turtle wax this weekend, hope I don't screw it up haha and make the scratches worse!
Krew Member
So I've been reading and stuff on rubbing compound, apparently it removes part of your clear coat and you can lose your shine? Any truth to this?
Krew Member
Discussion Starter · #11 ·
Dextreme said:
That is why I like the polishing compound as I showed you above. Much easier on the clear coat.
Got it, just afraid of screwing it up more, just got it, don't want to paint it yet
Krew Member
Discussion Starter · #12 ·
Ok ok, so polish, then wax, any reason to glaze before waxing? I have a huge bottle of mequiars glaze at home I bought for $.05 and I mean a 64oz bottle lol
As for my first post earlier, like dextreme said I ment use the polishing compound first soft stuff, if it doesn't work then go to the rubbing compund , they both have I think pummece in them , use the polishing type first , they both will start to chew into the clear coat but rubbing compound eats it off faster I think more grit, polishing is exactly what it says it polishes but takes longer to chew into surface i.e. more elbow grease as stated earlier
Krew Member
Discussion Starter · #15 ·
GRIZZLYJEEP said:
As for my first post earlier, like dextreme said I ment yat the polishing compound first soft stuff, if it doesn't work then go to the rubbing compund , they both have I think pummece in them , use the polishing type first , they both will start to chew into the clear coat but rubbing compound eats it off faster I think more grit, polishing is exactly what it says it polishes but takes longer to chew into surface i.e. more elbow grease as stated earlier
Alright, guess my last question is, once I polish it, then wax it, am I going to have to wax it every couple of months after that lol, I'm not a big waxer
I guess I don't mind doing auto detailing, I use the turtle wax ice it goes on with a sponge clear no compound its super easy to work with plus you can use it on your fenders and black stuff it really helps but waxing every six months or so wouldn't be out of the question for you , polish it glaze it wax it see how it works for you :)
Krew Member
Discussion Starter · #17 ·
Gotcha, so you use the spray wax? I was thinking of using that instead of the paste type wax, especially since I'm doing everything by hand
Krew Member
Discussion Starter · #20 ·
So i am looking at polishes and such because bluebird is getting the pampering this weekend. Looking at this Mothers California Gold Brazilian Carnauba Cleaner Wax that apparently has polish in it, think this might work instead of buying polish and wax?
1 - 20 of 32 Posts
