first to say i'm new to this forum and just bought my first jeep and i couldn't be happier.
Second, i bought a 2007 Wrangler 4 door and it is clean and well taken care of, BUT something that is driving me crazy is that the driver side seat seam to be loose sometimes. It clicks sometimes when i turn or go over a bump and i can feel the movement if i push myself back and forth when i sit on it...
Anyone else encounter this problem?? how do i fix it myself or should i just take it to a local shop and pay.
Any help would be greatly appreciated.
M
I think you're just feeling the loose play in the mechanism. If you can find the spot that it's moving, maybe you can "tighten up" the fit. Also, Make sure the bolts that attach it to the floor are tight.
Thanks for the quick reply, i did check the the ones attached to the rails and they seem plenty tight... i will definitely check the ones to the floor.
Thanks again
