01 wrangler sport.
When I take off my seatbelt it is not coiling back into it's house. Anyone have a quick fix I can try before taking it in to be replaced? Or is it something that I could replace myself?
Yeah it's kinda sketchy thinking about it. I really don't want to have my seatbelt fail me. Could also possibly result in a fail for inspection.
Its not broken or unsafe to drive with. It doesn't retract because after years of use gunk gets in the seatbelt and the springs wear out. A combination of wd40 to clean gunk out and lithium grease to lube it up will help.
I took mine off and knocked all the sand and crap out of it. its been working good for years now.
2nd on the make sure its safe first comment above
Thanks i'll see what I can do w/ this. Makes sense.
I may have to go try that on mine. I just assumed the spring had gotten weak and didn't know if there was anything I could do about it. At least it's not as bad as the one in my Blazer. It'll hang out the bottom of the door if I don't feed it back in :rolleyes:
