I have completed my install and it was two full days...
But I had added work...see...
Secured Rear Enclosure...
2 L7 -15" Square Subs installed with Kicker Amp.
Stained and clear coated with Polyurethane...
I added a couple of brackets across seam and 1/4 out from center to make front board and rear board stay level with each other...
I screwed the Plywood sideways to brace support. Then worked it down to tighten up the Torque Bolts I used in the hardtop mount location, mine can be run with hard top or soft top.
I used 13 dollar a spray can of Adhesive 3M spray to secure carpet to wood.
Wired up amp using an empty slot on SPOD for remote of sub amp...
which also has min power shut off to ensure start...
Permanently....Mounted to much aggravation to take on and off...
I like it and it serves a couple of purposes...
