1 - 16 of 16 Posts
Discussion Starter #2
Sorry, I thought the photos would be included on the post. Still trying to figure that out.
For those inquiring minds. I just had a TF 2.5" coil lift, Fox 2.0 Perf Series IFP shocks and BFG KO2 rubber in 285/70R17 installed. Other than needing to dial in the tire pressure, the ride quality is much better than I anticipated. I went this route as this is my daily driver first and foremost.
BEFORE:
https://dl.dropboxusercontent.com/u/3115560/IMG_1916.jpg
AFTER:
https://dl.dropboxusercontent.com/u/3115560/IMG_1921-1.JPG
When you want to add an image, use the icon 3 over to the right from the "insert a link" icon...its the yellow square with mountains in it.
Discussion Starter #8
Discussion Starter #12
Looks good, I also have a 2.5" lift, and was looking at running the same tires.
Thanks! The picture really doesn't do it justice. The tires look bigger in person must be the angle maybe???
Discussion Starter #15
was caster addressed (lower control arms/ drop bracket)? what was included besides the 2.5 kit/shocks?
Indeed it was. Front alignment was also done.
Discussion Starter #16
when I switched my oem KM tires to 35" ko2's, I saw improvements in mpg due to less rolling resistance from the AT. I also have a 6spd so its more noticeable to me. I hope it does the same for you.
Me too! Appreciate your insight!
1 - 16 of 16 Posts
