Have my front shafts out waiting on pinion parts . I ended up buying a new hub bearing but I need to get the old hub off of my axle shaft to my shaft back in. Anyone have any tips on how to get the froze hub off of the shaft? Thanks..
Remove the stub shaft nut, soak the splines with rust penetrant. Give it some time to work its magic. Use a three-jaw puller, will likely come right off.
