1 - 12 of 12 Posts
Can anyone supply me with one for a '98 2.5 4 cyl.
I'm pretty sure I got it on there right, but it has like 6-12 inchs of slack. Also do I need to tighten or loosen the bolt on the power steering pump to put more tension on the belt?
Banned
This diagram shows the fan belt routing for a '98 TJ, 2.5L or 4.0 L, with power steering.
This diagram shows the fan belt routing for a '98 TJ, 2.5L or 4.0 L, with the air conditioning and power steering
This diagram shows the fan belt routing for a '98 TJ, 2.5L or 4.0 L, with no air conditioning and no power steering.
Banned
If you can find me you can have me, otherwise :flipoff:
Mine are linked to stu-offroad.com anyway so im alright, not that I really give a shit anyway
Discussion Starter #8
Thanks guys. That helps so much. I still need to know if I need to tighten or loosen the bolt on the power steering pump to put more tension on the belt.
Discussion Starter #12
Nevermind, I'm an idiot. I didn't realize that the idler pulley right below the power steering pump is the pulley that moves to put tension on the belt. I thought the power steering pump actually moved like on my old cherokee with a 4.0.
1 - 12 of 12 Posts
