1 - 11 of 11 Posts
hey wrangler fans i just got a 2007 jeep wrangler sahara 2door 6speed manual trans just wounding if anyone knows how to remove the shifter knob any help would be great thanks
Congrats on the new ride and welcome to the forum. Hope somebody comments cause I'm.interested to find out also.
The service manual says its supposed to pull off with a quick jerk. If not it says to use a slide hammer.
Here's another method: wrap a small rag around the shift lever so it rests against the bottom of the shift knob. Take an adjustable wrench and tighten it against the rag/lever just below the knob. Hit the underside of the wrench in an upward motion with a hammer.
He may want to remove it to swap it for aftermarket or to remove the trim around the console.
The rag/wrench/hammer method can be successfully used to remove the knob without damaging it.
Banned
Ya mean it hasn't just pulled off in your hand? :D
:popcorn:
Banned
Haha mine did and the trim rig broke at the same time. Of course I did have a death grip on it at the time.
Yeah, I've heard of them just coming off in some peoples' hands. I keep waiting for it to happen. :hide:
:popcorn:
Not the shift knob. :D
I took one off using the method shown in the video. The top cap with the numbers didn't want to stay tight once I put it back on.
If you want to keep the knobs then I would recommend prying the lower plastic part off(down the shaft) with a screw driver , before using the wrench method.
1 - 11 of 11 Posts
