Yes that's what I was talking about. Thanks for makeing it make more Sence!jokerchief462 said:Loosen the lock nut underneath first!!
I pounded a pine apple grenade over mine. The hole in the bottom of it so you can tell its not loaded with a charge is like perfict fit for the shifter columnbigbuckd said:Just be careful. Thought I could just twist it off too. Used a cresent wrench and thought it was working fine till it just snapped right off. No biggy just cleaned it up and welded on a bolt and did some custimizing.
I know. Jeeps are so simple and easy to build how you want and how you like.bigbuckd said:That's cool. Stuff like that you can do to a jeep. try it with any other vehicle.
