1 - 15 of 15 Posts
So I just bought a new 2014 wrangler sport recently, and I was just driving it through some dirt roads while headed home (note it's entirely stock and I don't do any off-roading in it as of now) and I came across some deepish wet mud since it had rained earlier. I couldn't go around it so I slowed way down and just tried to put it in first gear and barrel through, it didn't go super well I'm assuming because while trying to get through without getting stuck it started to smoke and smell terrible, so I got through and turned off the car, did I blow my clutch or something? I'm no car expert by any means but it sure as hell didn't seem good so I let it sit there for a minute, there was no more smoke after I had stopped but it still smelt awful, it made it home without much trouble as far as I could tell, but i just want to make sure there was no permanent damage and if that is a regular occurrence in that kind of scenario. Thanks in advance.
You probably just threw some mud on your exhaust and burnt it. It should be drivers side right behind the plastic fender well. Its probably an orangish color. Also when you went in to first did you ride the clutch or were you fully engaged? If you ride the clutch you'll end up burning the bands in the tranny. That's the advantage to 4L you can fully engage much quicker (usually start with 3rd gear on flat ground)
Could it have been steam from water splashing up on the exhaust? Mine did the same thing today, but without the smell? Also, did you turn off the traction control? I didn't at first, and it started getting really weird, trying to maintain traction in sloppy wet mud. Every time a tire would break loose it would act like it was cutting out...once I turned it off every thing was great!
Discussion Starter #6
Good to know, thanks for the input :) I guess I'll just be more careful next time and be on the lookout for any problems, but good to know it probably isn't as bad as I thought :p
If you were fully engaged I really doubt it would be your clutch
Yeah I dont think the engine makes enough torque to be able to slip the clutch fully engaged and underway under any scenario. Im betting it was steam and mud usually stinks on the exhaust.
Retired Mod
When you went to 4H....did you put the vehicle in park an hold down the traction control button for 5 to 7 seconds? (Or even tap the traction control button)?
If not...that smell was the lovely aroma of your brake pads being chewed up as your traction control was kicking to stop your wheels from spinning while you were doing your best to keep your wheel speed up.
When you went to 4L....did you put the vehicle in park an hold down the traction control button for 5 to 7 seconds? (Or even tap the traction control button)?
Hmmm. I really thought that in 4lo, the tc was automatically off? Or is that 6 spd only? Just can't recall right now!
Troy
Retired Mod
Troy
You are correct....
I meant 4H...
If you go into 4H without turning down (or off) the traction control system, you will chew up your brake pads trying to spin through a lot of mud.
Retired Mod
Gotta love safety
Yeah...I wonder how many miles I took off my rear pads about a month ago when I was out in the sticks and got into some mud (which is something I said I would never do again...mud).
Like a dummy, I thought I would blast through it in 2H....until I found myself stuck (because TCS kept trying to apply the brakes while I was trying to keep the pedal to the floor).....whoops.
Luckily, I remembered to put it in park (auto), put it in 4H, then hold down the ESP button until it beeped. That allowed me to get some wheel spin going, and I was able to rock myself free and enjoy the scent of freshly roasted rear brake pads. :censored:
1 - 15 of 15 Posts
