Things can be lost in translation online, but if I had a shop, and you bugged the **** out of me like it sounds you did with him, I'd charge extra too.
That’s basically a 34” tire. You run at 30. I need to drop mine down a bit more. I ran 28 in a 33x12.5x15 on my TJEven with the stock LT255/75R17 tires, I found the Jeep handles and rode better at 33 than the specified 37. I would have gone down to 31 (as I had done on my '15 Sahara) but the TPMS nanny objected. I have since used the Jscan to reset the alarm threshold on my '17 to 25. I run 30PSI and it rides and handles well on my LT285/75R17 tires.
Good instructions.... and yes, alignment is Sooo easy on a jeep compared to other vehicles, you can do it at home pretty easily, and it doesn't take that long either. Save yourself a boatload in shop charges.In general Firestone will not get to involved with nonstock setups other than adjusting toe. And setting up caster on most adjustable control arms is time consuming as it involves disconnecting control arms to make the adjustment hence the increased cost to have it done.
But setting up caster at home is fairly easy. The first thing you are going to need is an angle finder. I find the digital ones to be easy to use and very accurate. Set zero to whatever surface you are working on.
My error - the correct spec for the tires on my Chief are 285/70R17 which are 32.8" tall (basically a 33" class tire).That’s basically a 34” tire. You run at 30. I need to drop mine down a bit more. I ran 28 in a 33x12.5x15 on my TJ
My JK currently run about 32 but it’s still too high IMO on a 33.2 (285/70/18)
Even better. Is that a 2d or 4d?My error - the correct spec for the tires on my Chief are 285/70R17 which are 32.8" tall (basically a 33" class tire).
Ok cool. Sorry for the derail. I just have not found that perfect pressure for my 2d. I need to look up the weight difference in an 05 TJ bs my JK. My TJ rode like a Cadillac of Jeep’s lolFour - JK Unlimited
Unfortunately not yet. It’s all stock and I think the shocks are stretched too with the 2” BB that’s under her. And that was a typo. It’s 33.2zipman35 - I run about 28 in my '03 Rubicon with LT245/75R16 tires. Of course I don't have to worry about a TPMS nanny in it. Your 285/70R18s are most likely Load Range E which have a stiffer side wall. The tires on both of my Jeeps are LR C. If your avatar is with the 35s you have a lift on your JK. Have you installed adjustable LCAs in front to adjust the caster back close to stock spec? It may not help the ride, but will help the handling.
Makes sense, the numbers are the numbers. Calling an alignment "just toe" alignment when there is caster to wiggle is not a true alignment, but I had given up, gonna try and do it my self again.Installing a lift will change the numbers, but not what the numbers should be. Can't change the camber easily and a lift won't. Toe in can be changed and the correct specification should not change. That leaves castor. Lifting a Jeep will change the castor and the purpose of the alignment is to bring the castor back into spec (or at least closer) - which has not changed. The way this is done is by changing the length of the control arms, most often the lower. This is the purpose of the adjustable control arms.
I used my iphone "bubble app" for an approximate caster angle and with the floor not being level (appx 0.7 deg, and measuring from the differential ( I used several locations) I got from 2.0 deg to 1.4 deg. In other words my caster is way below 4.0 degrees. I used bolts on each side as well as the flag flanges you circled in your pick. There was a video where a guy took of his tyes and set the truck on his brake disks and then a tool like the FASTTRACK to do an alignment lolIn general Firestone will not get to involved with nonstock setups other than adjusting toe. And setting up caster on most adjustable control arms is time consuming as it involves disconnecting control arms to make the adjustment hence the increased cost to have it done.
Angle Finder
Next here is a picture of the front differential. As you can see pinion angle and caster have a fixed relationship. With 0 pinion you have 6 degrees of caster. As you rotate the pinion up you lose caster. Most of us shoot for 5 degrees of caster meaning that you pinion angle is going to be 1 degree up. But as long as you are 4 degrees or better you are good.
I find measuring off the pinion flange to be a pain so instead I measure of the front of the diff as shown in the picture below. With the angle find zero'd to the floor and set for 180 measurements your angle on the diff should be 95 degrees.
Last but not least a couple of words of caution.
First only adjust one arm at a time. Write down how many turns you adjusted it and after you have reattached that arm do the other.
Second look at your rod ends, they are probably offset meaning you have to make full 360 turns of the end. With the lift I own caster is adjusted via the upper control arms allowing for half turns which don't have an offset.
This is not hard but it is time consuming. Taken the initial measurement, then jacking up the vehicle, removing tires, making the adjustment, putting tires back on lowering vehicle, taking measurement then repeating if it is not correct. If you can find a shop that works mostly 4x4 or Jeeps that does alignments you can pay to have it done but it will be a few hundred dollars.
LOL yeah, I will try the lower PSI as per your recommendation. I remember that when I first got the JKU I started at 40# but felt comfortable doing 33-35# after playing with the CHALK test when I had Cooper Discoverer AT3 (me previous tyre). Still have not played much with the Destination MT's as they are pretty much brand new.For 35" tires I think you will find better results at around 28 - 30 psi. Larger tires do not need as much air pressure in them to support the same load. The stock air pressure spec was for the stock tires and means nothing when you are running 35" tires.
yeah absolutely, lost in translation can happen. JAJAJA maybe I did bug him over the phone when asking about doing the alignment under the 1 year warranty. There is another well known alignment shop that I might try out.Things can be lost in translation online, but if I had a shop, and you bugged the **** out of me like it sounds you did with him, I'd charge extra too.
Looks awesome that Fasttrax level. Back in Winter 2020 I looked around for tools to do my own alignment but I was in a rush and tried using string and good old tape measure. My accuracy felt so poor that I felt that 1/8 of an inch adjustment was impossible when my measurement seemed to be +- 1/4 of an inch. I had seen some others use stretched plastic container from milk or O.J. for turn plates lol; I use them for installing my moto tyres onto the rims and some lube.Good instructions.... and yes, alignment is Sooo easy on a jeep compared to other vehicles, you can do it at home pretty easily, and it doesn't take that long either. Save yourself a boatload in shop charges.
I use fastrax though. It's a bit more expensive than an angle finder, but you can shoot a measurement in less than a minute without even climbing under. It's fast, simple, and clean. You can also get the optional toe measure kit with it if you wish. They suggest a turnplate in the video if you have one, but it's not absolutely necessary.
Besides me being an idiot, I get it now lolIf your pinion angle up (refer to the picture I provided) you have between 3.3 - 4 degrees of caster. If your pinion angle is down you have between 8 and 8.7 degrees of caster.
I ran these same tires for a lil over 3 years. You have way too much air in them even at 35#. Drop down to 26-28# range and you'll find that they ride and grip better.My tire pressures (Fire Stone MT Destination MT) were 37# all around untill I went to 35#
If your measurements are correct no you don't need more caster. If fact I wonder if you are running to much. With a stock driveshaft you pinion angle should be the same as the output shaft of the transmission (see picture below. One degree either way probably does not make much difference but the further away you get from it can cause unwanted vibrations and lead to pinion bearing failure.Besides me being an idiot, I get it now lol
Pinion measures down 1.7 degrees (floor is 0.4 degrees sloping down too) so the pinion really measures 1.7 MINUS 0.4 so it is 1.3 degrees.
Because of the built in offset of 6 degree from pinion to the C (6 degrees down), my caster is 6 deg down Plus 1.3 deg down so 7.3 degrees!! is this correct?
FYI, the shop wanted me to extend my lower control arms to "push the front axle forward", estimation was no more than 1/4 inch of the lower control arms. Very likely as misunderstood as that would add caster and IF my last measurements are correct I do no need to add more caster.
