Anything is possible. If I were you I would go over it with a fine tooth comb ( axles, Trans, TC). there is access to everything to rebuild one of those, just depends on what you are willing to spend. Rock crawler, 350, Dana 60's Tube frame. Everything has potential But thats just methe body has some bubbles starting to form and the frame didn't look to bad. another question is: it looks like its an automatic. is that possible
a Jeep for $1,500 sounds good ..depends how much talent u have to transform it.on the way to work today i saw someone selling a 65 cj5. called the guy and he said he wanted 1500, but could go lower. it's going to need a new head gasket and has about 190,000 miles. should i even consider this or just run away?
