1 - 20 of 30 Posts
Anyone came up with a good way to quite the 3 piece freedom top! Cant hear the stereo at 70mph on the hiway! And ive got a BIG stereo!
Is it that noisy? Wind, or rattle?
Just curious...my OE soft top (as well as my aftermarket ORH top) makes very little noise. I can talk on the phone at 75 mph, no problemo. :thumb:
Might need to check your seals then because my hardtop was quiet. No wind noise at all.
my 2010 is quiet. Slight wind at 70 but nothing bad. Off and on.
HookmCowboys said:
Was hoping someone found some GOOD seals to use!
You can try some weatherstripping from lowes or home depot. I use them and they stopped water leaks so it'd probably work on air too
:whistling: The cure is-
Insulate the top, make sure the front doors shut INTO the top door seals and eliminate any possible windshield leaks at the upper gasket !
Mine is "whisper" quiet at 70 mph and cell phone use is normal/no leaks either/no sun heat-
Good luck
:dance::rofl: JIMBO
Good luck
:dance::rofl: JIMBO
+1 :thumb:
Make sure all the doors are shut tight, and none are misaligned.
I normally have the factory stereo at 10 volume at 70mph and can hear everything great.
Mine is loud too with lots of whistling but I have no leaks at all so far. I chalk it up to being a Jeep so being loud for me might not be relative to being loud to someone who is used to driving a Jeep.
Mine is not even that loud with the Freedom Tops out. I would take it back to the dealer and get it fixed under warranty.
1 - 20 of 30 Posts
