1 - 20 of 25 Posts
Hi Guys,
anyone can recommend an "aesthetically" nice fuel tank holder to mount on the side (not rear) of my JK?
Thanks
Check out RetroFit Off-road. They have a couple of options and an EX-member of WranglerForum.com, jsherb designed them. He’s no longer a member on here bc of some stupid BS. You can find him on the expedition/over-landing site. Super nice and friendly guy. Hope this helps ya!
thanks bro!
I can’t speak to the owner of that site, but he carries Mor/Ryde accessories which are very good. I have the full tailgate system and love it. I’ve been eyeing the rotopax mounts as an upgrade.
There is also a company that makes a mount for the hardtop that covers one of the rear side windows.
Bro, can you share a picture of the tailgate system?
Thanks
Hi Guys,
Thanks
Yeah... I had the same issue. Try and find a side mount system which doesn't look like something out of a Frankenstein movie. I finally just built my own out of angle iron and cargo straps.
4464370
4464371
4464372
4464373
Thanks
Here you go. They make a Hi Lift mount and a Rotopax mount that go to the passenger side of the tire. They also make a shelf that goes above the tire.
Reactions: Lupo81
Do you happen to have pics on how you attached it? I too am looking at mounting jerry cans to the side but the Morryde jerry can holders are 170 per side. A bit on the pricier side so looking to see if I can DIY it.
No pics of its attachment, but it has been drilled and bolted directly to the fender (large washers as backing inside the fender). Some worry about the resale value after doing this sort of thing, but I am not one of them.
Have the Morrhyde ones. They are a spendy proposition, especially if you get the roughly $70 a pop Wavian cans. Having said that, they have served me through all of my travels without a single issue.
do you guys prefer side or tail support?
Personally speaking I prefer the side. The back door already has some serious weight on it and you're not going to get full fuel tanks on there without stepping up the carrier so now you're talking not only new tanks and a mounting system, but also a new carrier if you don't already have one. Now if you already have a heavy duty carrier then you have some flexibility but if you don't then a reasonable carrier is going to be an extra $400 to $800 on top of tanks and a mount.
Grumpy Old Guy
Advantages and disadvantages to both:
On the trail, especially with trees and branches, the side mounts can get beat up or though the potential is small, torn off. Ease of access is great.
On the rear, like @bobsanders said... it is added weight that can add to sag of an already soft or overloaded rig. Especially if you are adding 2 4G Roto's (8x8 = 64lbs) or 2 5G Jerry's (8x10 = 80lbs). That's essentially equal to a 2nd tire/rim combo hanging off the back. On the upside, there are many variables on how to mount Rotopax and Jerry's. Bumpers, swingaways, specific mounts/brackets. On the front, you have really only have two options - MorRyde or DIY.
I went to the back on mine. a 3G Fuel and 2G Water Rotopax with a semi custom mount I made. It is a Rotopax plate, but I drilled 3 holes that run through the plate, through aluminum spacers and into the lug nuts of my tire carrier. I don't have a pic for some reason. I'll grab one later.
Discussion Starter #16
thanks bro!
Discussion Starter #17
Thnaks bro, very useful comment :)
I added a 3 1/2 gal Rotopax onto mine. It was cheaper than adding a metal 5 gallon can. Between the extra cost of the seat for the gas can and a good quality gas can itself I decided to save money and go with the Rotopax setup.
On a prior Jeep I mounted Jerry cans. Never needed the extra gasoline. Haven't bothered with extra fuel on current JK.
1 - 20 of 25 Posts
