i have 94 Jeep wrangler,
Problem:
When I turn on the headlights "on dash" the right turn signal stays lit (front bulb is off); if i turn on the right turn signal it works, front turn signal blinking normal.
Hazards work normal
things i have done:
replace signal relay
replace bulb
verify all other bulbs are normal
no other problems!
I would start basic and check all the contacts and make sure they are clean of any corrosion and the wiring is in good condition.
When you are getting "feedback" that is causing an indicator light to come on in the dash, such as a turn signal, it usually indicates that there is a bad ground on that light.
Take that front light out, turn the parking lights on, and use a multimeter to see if the ground is working on the socket.
The plastic twist in sockets rattle loose, and cause a short. Sometimes they can be taken apart and the prongs tightened, others just need replaced.
