1 - 14 of 14 Posts
Will try to make this short and sweet
Just some info:
2010 JKU Sport 6spd
from the dealer
33" Terra grapplers i got for very cheap. Shortly after I regeared to 4.88, sleeved, gusseted, and skidded the D30
Teraflex 3" with front upper and lowers, and rear lowers (
because every noob needs to use an RTI ramp at least once
Prorock 44 with Dynatrac balljoints, ARB, 4.88 and RCV
and my D30 (sleeved, gusseted and geared) below
Rear shock/arm skids...
Evo protek skid
skids welded to the prorock44
EVAP relocation
Rear ARB
Discussion Starter #2 (Edited)
...and then i got 35's (used)
35's + JK stock steering = no...soooo that means...
Poly Performance trackbar bracket
PSC ram
PSC Steering box
PSC Reservoir
12" heatsink style aluminum cooler, teraflex draglink flip, and poly performance track bar (had issues with existing teraflex trackbar after raising the trackbar)
New MTR (35x12.50x15)
Discussion Starter #13
with my JK approaching 50k miles, i felt it was time to take care of the cooling system. so since i need to drain the coolant, i decided to replace the waterpump, thermostat and radiator at the same time.
fan/shroud off
stock radiator off
i went with the Mishimoto aluminum radiator. if im going to remove it i might as well upgrade. i dont have the exact measurements, but it's maybe about 3/4" thicker than stock. and no more plastic end tanks
TO BE CONTINUED
1 - 14 of 14 Posts
