Torque at 30? Mine had to have been at 90 foot lbs! 30 seems kinda light.jokerchief462 said:My choice would be anti sieze. I used wheel bearing grease on the threads and the shank. Torqued as per FSM 30 ft/lbs.
Mine had minor rust when removed. I cleaned the the frame nuts with a bore brusj stuck in a drill, cleaned the bolts on a bench grinder wire wheel. Treated for rust painted the bolt heads. Seems fine.
Great info, thanks.
BOOKMARKED! Great link!
