Hey, 2013 JK 2door
I just recently ( 2 weeks ago ) changed my gears from 321 to 488.
Installed ARB lockers also-- I have a slight vibration which gets worse the faster I go, would the drive shafts cause a vibration if not installed exactly as they were before being removed for the gear change ??
Was thinking of taking the front shaft out and drive it to see if the vibration goes away and do the same for the rear. I have brand new Tom woods drive shafts now, just haven't installed yet.
Would the gear change cause a vibration if maybe he didn't install right ??
It has no noise, and everything seems fine other than the slight vibration.
Thanks !!!!!
I would lean more towards install than the driveshaft.
I have had my d's out more times than I can count and have had no issues upon reinstall. Would pull the dif covers and see what's what internally. Most likely the install since that's the most recent change.
And if it is one of the shafts at least you already have your fix
Sent from my SAMSUNG-SM-G891A using Tapatalk
