I got bored the other day, so I welded up two lockable military 5 gallon gas can holders for the Jeep. I will use them for trails when I need them and for car show displays. I decided to mount them using the uprights for my roof rack. I used two eye bolts in the rack, this way I can remove them easily when not needed. The bottom of the can rack is about 1/2 inch above the Jeep body. I can still get in the tailgate. If I need to open the rear window I only need to swing the gas rack out slightly. I will post some pictures soon.
updated with pictures
i got bored the other day, so i welded up two lockable military 5 gallon gas can holders for the jeep. I will use them for trails when i need them and for car show displays. I decided to mount them using the uprights for my roof rack. I used two eye bolts in the rack, this way i can remove them easily when not needed. The bottom of the can rack is about 1/2 inch above the jeep body. I can still get in the tailgate. If i need to open the rear window i only need to swing the gas rack out slightly. I will post some pictures soon.
