I have a 2 DR. and just bought new wheels and tires 285/70/17 and just realized what the difference was for tire rating. They look great. And the ride is a tad bit softer than stock... i was looking at weight of tires and im not to far off the normal tire weight of this size at 65 lbs...? I have a manual with 3.73. Do you forsee any issues with this tire?
With an E rated tire, you'll find that the ride will be really stiff. I have e rated BFG All terrains and I had a problem with them for a while. Just keep your psi down around 30 and it should keep everything in check
An E rated tire (10 ply) should ride much stiffer then stock. My D rated (8 ply) rode stiffer then my C rated (6 ply) Rubi take offs so I aired down to 28 psi and now they are much softer.
You won't have any issues with your tires. I run 305/70/16 (33's) with 3.73 gears which is a perfect combo.
Did you notice a major change in gas mileage?
The tire size you are talking about is moderately different from stock so unless you expect your Jeep to ride like a car, you will be fine that tire.
