Good day to everyone,
Just finished an SOA conversion on my 95 YJ and having some driveshaft vibration issues. I used the RC perches and installed a tom woods SYE. Unfortunately I did not have the drive shaft when I set my pinion angle and I am pretty sure I set my pinion angle incorrectly and that is causing my vibration. I mainly feel it when I am applying throttle going forward and it settles down at low throttle conditions. Also have no vibrations in reverse.
Using my protractor I currently have 17 or 18 degrees on my drive shaft and 23 or 24 degrees on my pinion.
Basically looking for some confirmation that I need to install a 6 degree wedge to drop my pinion angle down and if 6 degrees will be enough?
Thank you for your time and I appreciate your help.
Shawn
Shawn
