i was wondering if i do an soa on my 90 yj if when i weld the perchs onto the axles could i just point the pinion more straight to the transfer case. Im a little tight on money so i dont want to have to buy an sye and a cv driveshaft.
That is something that will have to seen, as you do all your adjustments. Do not be afraid of the Sye, as it will alleviate, a lot of your problems. Not to mention making your world, much happier.
Hacks off Parts while Lit
if u are not running a CV driveshaft, your u-joint to driveshaft angles should be equal on both ends. if you're running a CV shaft, point the pinion towards the t-case. actually, you may gojust a little bit lower than towards the t-case as the axle will rotate a little upward under acceleration
