I have a 2015 wrangler unlimited with factory soft tops
I noticed today that the top on the passenger side is loose and flopping along the top of the passenger rear and front doors where it should be snug against the top. there is a seam that runs the length of the underside of the fabric with a small diameter metal cable running through it. it appears the cable has broken. this is causing the top to be loose and not rigid.
has anyone seen this?
Thanks.
Thanks.
