I'm buying a soft top from a private owner for my 92 yj and the guy said he did not have the windshield channel, the tub channel or the (what he explained as) things that get sandwiched between the roll bar and windshield frame. i have herd of the wind shield channel but can anyone help me with what hes talking about with the other two parts missing and where i could get them, any help would be awesome, thanks.
If it's a supertop, there are brackets for the door surrounds that go between the windshield frame and the roll bar. If I remember right that is ;D
Yjs have more hardware than anything for soft tops. You will need a windshield channel, l and r plastic stoppers that screw to the windshield to properly seal your uppers, soft top frame that slides into metal channels and clips into plastic stoppers, an all metal brackets that the top tucks up into (held by big torx bolts) plus metal support bar for rear window that slides into metal brackets in the back (goes across your gate an seals it). Huge pita. You might get lucky with craigs. I did. Parts are more $ than the top. Hope it helps.
