My side soft panels are flapping in the wind when I go over 55mph.. It's because the lip that gets tucked into the door end is coming out. Is there a trick to keeping that in or is this normal for the side panels to suddenly get loose while driving!?
Thanks for your help!!!
Retired Mod
Welcome to WF :wavey:
See this thread....http://www.wranglerforum.com/f274/soft-top-help-563993.html
The answer is "yes"...there is a tip. You need to rotate that edge of the panel another 90 degrees. If fits into the channel like a squared "U", not a squared "L". (The door does not hold it shut)
Yeah I did the same thing first time I took off my windows. Just folder it over into the channel there. Once you do that it never moves.
It's easier if you unzip the side windows to the top first...helps make it a lot easier to put the "L" into the slot.
Retired Mod
Woooooooooww I feel like an idiot!!! Thanks so much for the help! It's appreciated!
Don't feel bad....pretty much EVERYONE (myself included) screws it up the first time.
Glad we could help...
