right, I can make a surround to cover that gap around the door, I'm just wondering if that plastic piece that attaches to the windshield will prevent the full door from closing (bestop has a different bracket that OEM).If I am reading right you say you can mod the doors to work, if so I believe the doors not the windshield will give you any issues at all. Make sure you have it all, including the back window to tail gate seal.
I have this set-up so I was just seeing if I can use it... I'm not going to buy a supertop, I'll just continue to use my raincoat if needed, lol.Nope you'll need the supertop from bestop
right on, that's what I was wondering... thanks!!The plastic pieces running down the sides of the windshield frame will interfere with full hard doors. If you don't remove them, the doors wont close. I've almost busted them a couple times because I forgot to take them off when switching from half to full doors.
Same hereThe plastic pieces running down the sides of the windshield frame will interfere with full hard doors. If you don't remove them, the doors wont close. I've almost busted them a couple times because I forgot to take them off when switching from half to full doors.
