when i have the sun rider down the side soft top windows don't stay tucked in at the top is this normal thks
Don't stay tuck in at the top??? What? Of course your windows will flap, the only thing they could flap against though is the diagonal bar... If the sound bothers you that much, go out and buy a seat belt cover from wal-mart... Voila, no more sound
I don't think I'm following the OP here...
Have you taken them out? It sounds like they are not installed correctly. There is a stitch going up the side of the window panel that should be tucked into the door surround.
Also, when in sunrider mode make sure you unzip the back window a bit.
Sounds like you do not have the leading edge of the window in correctly. It's fits in the door surround like "C" channel, not a "L".
